- Apr 5, 2007
- 425
- Vinyl
- Hayward Aqua Rite (T-15)
Hello all!
I have a pentair solartouch operating my solar heated water. I noticed that water was coming out of the center post of the valve through the actuator as well.
I replaced this part and all was fine with the leak. But...
With the water that was leaking earlier the inside of the actuator was wet inside. The actuator would not turn to one side or the other. It just kind of stutters. When I ordered the new insides for the valve I also ordered the new micro-switches and a set of o-rings. I replaced the micro-switches and
the motor still stutters. Looking at the board with all the wiring harnesses and switch, it looks like the switch is a bit corroded. If I lift one of the wires on one side of the limit switch the motor will turn to the other limit and turn off. If I plug that wire in it stutters again, but now if I pull the other limit switch wire the actuator will turn the other way.
I've thought about getting a new switch for the wiring harness board, or a new actuator, but what if the problem is in the Solartouch control unit.
thoughts or any help is appreciated! (not sure how to get the small videos to come through)
