- Mar 16, 2013
- 25
dccordell said:Has anybody tried the modified fittings on these twist-plunge valves? These are the valves included with our new Ultra Frame pool. It has this "nub" that sticks out of the valve where the hose slides on and seals via the o-ring. The nut itself has no seal, as it is just used to hold the hose onto the "nub". I think I either need a fitting that will slide over the nub, or cut the nub off altogether.
I would just replace the entire valve with a ball valve, but I still have this same problem on the pump. Any ideas?
Pool side...
Pump side...
I just did this yesterday. I went to my local hardware store and bought some rubber gasket material. I used the electric conduit adapter everyone else has been using. I traced an outline of it onto the rubber material and then cut it out very slowly trying to make the most round edge I could. I didn't modify the plunger assembly in any way. I just slide the gasket all the up the assemble past the "O" ring and then slide the conduit adapter with nut on and snugged it up. It hasn't leaked at all.
Question, has anyone else had a problem with their hayward skimmer leaking so very very slightly around the seal? The leak is hardly noticeable. Wouldn't leak and inch of water in a year probably but I'm a perfectionist and can't stand that it has a small leak.
