Bowlin said:
Nah just bought the bleach from wally world 8.25% 122 oz's
That's exactly what we use and we don't have any problems.
Concerning your original post, let me offer my personal experience. Let me say first of all, I'm an amateur, am not deep into all the technical details and in depth knowledge most of these folks can offer. But, I have had some success keeping my pool clean and I can tell you what I am doing and what's working, and you can take it for whatever it may be worth to you.
For the record, I have, and use, our own test kit to keep track of things. We are also fortunate in having a family owned pool store that is more concerned with customers having a clean pool than selling chemicals. Oh, they make recommendations but, they don't try to tell me Clorox won't work. They are really very helpful. I use them to test MY test results. If there is any major discrepancies, and there haven't been many, I bring the debate here for clarification.
For one thing, I live in East Texas so our (mine & Bowlin's) climates are likely comparable at least to some extent. Also, like you I am using Wally's bleach though, and I don't really believe it makes a difference, my wife insists on "Clorox" brand.
For another thing, it is gonna cost you to clean it up. No way around that but maybe not as much as you're spending now. For several years running, I opened each spring with 23,000 gallons of stinking green, primordial ooze.
No more but, more on that later.
You do have to have the cya up too.
I tried using the chemical calculator referenced elsewhere on this site and was given to use something like 5 bottles of the, I forget the size exactly- the bottles that were a little less than a gallon and a half- to super shock it and it didn't really accomplish anything fast. I got po'd one day, said the heck with it and dumped like 10 bottles in there and let it rip. It worked. Now, maybe I misused the calculator. I wouldn't be at all surprised cause I did have trouble with it.
But, overnight my opaque green turned translucent grey. I did the same again and that pretty well cleared it up. Oh, there still had to be a lot of scrubbing and back washing but, that took a strain off the chemicals.
Now, here's a curious thing. Every year near the end of the season (September about) I seem to get a determined algae bloom. "Normal" shocking and algacide just wouldn't stop it but, being end of season I usually gave in to it until spring. Well, 3 years ago I decided "No."
I dumped my "super shock" dosage of "Clorox" and it knocked it right out. Then, strangely, It stayed clear. All winter I pretty much only, added some bleach if it started getting cloudy but, only about 3 bottles at a time, 5 if it seemed determined. That and, not having a cover and being of two minds about the wisdom of using one, simply cleaning out any substantial leaf or such like build up as it occurred. Pretty much, unless a storm blew in some trash I only did things to it about once a month. Also, I would normal shock the pool if we got some heavy rainfall (Not as frequent an occurrence as I we could use.). Come spring, I hardly had to do anything special to open it. Mainly just some good brushing and vacuuming and properly balancing the water and that's it.
The end of the next season, came the usual algae bloom and like the previous year I knocked it out. That winter and spring, same thing, no headaches. This past year I went into it with that in mind and again, it stayed pretty clear all winter.
My fill water, btw, is ph high well water in case in matters, though, last year I had little problem keeping the ph in line, usually a struggle. I used to use nearly as much acid as bleach! Maybe the drought, bad here in East Texas year before last had some effect on it. I don't know.
I hope this helps somebody and I am anxious to hear what wiser, more educated heads have to say about it.
(And let me hasten to assure, I am in no way being smart alecky or sarcastic in that "smarter/wiser" comment. I am literally in awe of, and have great
respect for, the accumulated knowledge here.)
Sorry all, that this is so long but, I wanted to put what I did and what happened in detail because I really don't know what, or even IF I am doing anything "right." I only know what I am doing is working. Maybe it's a fluke?
Anyway, there you have it. I only know it's working and has for 3 years straight now.
