First complete readings this spring as follows:
Ph 7.8
FC 8
CC 0
CH 600
TA 110
CYA 45
Temp 77 (water)
Salt 2850
CSI 0.44
Added 32 oz 31.45 acid. Did not make other adjustments till I consulted with the pros on the forum. Obviously my CSI is too high. CH went higher in a mostly dry Spring. Should I bring Ph down to 7.0 or so thus lowering TA? Will that also bring CSI down or am I resigned to draining some pool water? Thanks for your input.
Ph 7.8
FC 8
CC 0
CH 600
TA 110
CYA 45
Temp 77 (water)
Salt 2850
CSI 0.44
