I use a solar cover and this morning after rolling it up, there were areas of algae, mostly where the sides meet the floor. I check chemicals daily and keep my pool clean. I also brush the walls from time to time. This has been happening on and off this season. Looking at the pool I knew the water was in balance - it was crystal clear. Using the TF-100 test kit, these were my results: FC 3.5, TC 4, TA 100, PH 7.5, CYA 30. I usually have FC/C 4-5. I use liquid bleach. Prior to the rain the other day I had 0 CC. I can't figure out why I'm seeing algae. Can it be that my water isn't circulating enough? I have a variable speed pump, running all the time but I have to check that it is adjusting. Usually in the morning I manually turn it up to high. I have shocked it - bringing chlorine up to 12 about a week ago. I usually don't have to shock the pool once I get everything in balance. My pool is 33,000 gal, vinyl liner. (My liner is old and faded - could that be a problem?)
