Gordon,
Below is a screenshot from my EasyTouch that might help a little.. Notice the titles across the top.
"Circuit" is a factory name that can't be changed.. You can see that the units come set up with a basic set of Circuits... Such as Pool, Spa, Aux 1-7, Features 1-8, etc.. Each Circuit has a relay that it controls.. The relay usually controls something that needs 120 or 240 Volts AC to run... As an example.. If you want to control a light, you must use an Aux Circuit, because you need a relay.
Feature Circuits work just like Aux circuits, except they do not have a relay.. Feature Circuit are used to control things that are internal to the automation, such as pump speeds, and valve movements, and I now suspect Macros..
"Circuit Name" is what
you want to call the Circuit.. As an example.. you could call Aux 1, Aux 1 if you wanted, or you could call it Lights, or Dog Food.. It is
your name for the Circuit.
"Circuit Function" is only used if you want the circuit to do something special.. If not, just leave it at Generic.. As an example.. If Aux 1 is for a standard light then Generic works just fine.. But if you want Aux 1 to control an IntelliBrite light, then the Circuit Function must be set to "IntelliBrite"..
I know that does not solve our problem, but it should help you "speak" a little better Pentair..
View media item 1964
Jim R.
