- Jul 15, 2012
- 636
- Plaster
- Hayward Aqua Rite (T-15)
21 year old gunite/plaster pool and spa. Pool area largely fill with piles below - reinforced with additional piles 11 years ago. Pool used to crack every year around shallow end skimmer - finally seems to have been fixed 3 years ago by redoing the rebar and reshooting gunite in shallow end. Had a few small cracks on pool side of wall between pool and spa repaired 11 years ago. No cracks there since.
I have needed to replace the grout between the coping stones on both the pool and spa every 3-4 years. Seeing it again this late summer, with small cracks in almost every joint. Experience says water will get in during winter freeze and expand, such that cracks will be larger next year and water will get under the coping stones and the tile. If I dont address issue this year, I'll have a bigger problem to address next year. Note in my photos that in some places, the crack extends from the coping stone joint to the grout between the pool tiles.
Any ideas why these cracks occur. Is there a better or worse substance to use for the grout that better deals with water and freeze? The coping stones have a large expansion joint away from the patio stones (which sit on concrete base). Is it possible that there is movement between th coping stones that does not manifest itself with cracks in the pool? Any suggestions on what I might do to correct?
