This is good information. But I just learned the handyman had a stroke 2 months ago and says he can work only 3 hours at a time because of the pain in his limbs and limited movement....oh my gosh. I'm a 63 yr old widow. Lots of friends disappeared on me in 3 years. I figured it wasn't rocket science but those pool pro guys sure act like it's so dangerous and tedious. Leslies wanted 1800-1900 and a local overbooked highly rated guy said 2100. I said wow the tank is 800 and the sand is 150 and he said, yep and it's a lot of hard work. Anyway, I will order the supplies and the tank. It's a Tagelus, can't read the model but with a 28k inground, I'm guessing it's the biggest one, 100D. Yes, some pool guy talked me into adding the silly puck thing that was never used. I will get a shop vac that maybe I could use for something, not sure what. So adding this all up, a filter (800 plus tax) 866, sand 155, shop vac 80, PVC pipe, PVC cutter, primer, glue, tape 60...approx 1200-1300 then handyman labor approx 300. I guess I'm back up to 1500-1600 believing the handyman is up for it. Like you said, mknauss, I can start removing sand before he comes. And as tim5055 said, have it circulating for now. I do need to deal with that leaning concrete slab before it is set down. Any suggestions on how to do that quickly will be appreciated.
