Good Morning- AJW- I replaced last tear and they cracked again this winter as it’s 15 degrees out… is this going to happen every year? How do avoid these cracks- different stone material? I’m lostIgnore it or replace the tiles.
Is thereThat appears to be travertine tile which is porous and allows water to penetrate any voids, then freezes and cracks.
Sorry to say this but I can think of no fix other than replacement,
Thank you- it appears the deck side is “lifting” a touch and that is what is causing the cracks since it’s the entire length of the pieces- all in the same general area- if I replace them again is there a different type of stone or different practice to prevent this in the future or am I SOL?That appears to be travertine tile which is porous and allows water to penetrate any voids, then freezes and cracks.
Is there a way to remedy this- for example change the material on that side- different stone etc… what’s the correction that I can do that you know or who I may discuss with? Possible flex travertine for that 10’ space?If there is movement in the decking, the cracking will continue. Basically, the tile is rigid and has no "flex" to move with the decking so it cracks.
