The freeze got my chlorine feeder, it pretty much cracked top to bottom and has a pretty fast drip.. and pool water level is already below skimmers. (switched to pulling from main drain only)
I had the pump running most of the time (when had power) but forgot about the water sitting in the chlorine feeder. and the valve to it was turned off.. thus froze solid and cracked.
Trying to get the parts before taking this apart and causing a bigger leak... but wanted to check if the top section can be removed and from the PVC and a plug installed?
or is the Chlorinator and the T in the PVC one piece?
attached pic.
Thanks
attached pic.
Thanks
