Pool has been chipped to the shell.
Multiple issues:
Multiple issues:
- Need to fill the void of loose gunite that has been chipped out at the turn from the wall to the floor of the pool. Max depth of voids is 3".
- Anyone have experience on how/if it's possible to layer new portland cement on to a pool shell?
- If so, how do you do it?
- Need to tie in steel or just chisel to good shell, acid wash, bond agent and pour over?
- Can you skim coat the pool shell to give a smooth surface for the new plaster?
- Need to fill pool crack that developed.
- Other that shooting new gunite, is this a DIY effort?
- I was thinking I would use tapcons to boardroom the gap and fill/vibrate from the bottom up after acid prep and putting a bond agent on the sides.
- Other ideas?
