Model number: EC-0001
It’s older model automatic pool cover, from what I can tell. Been here since I moved in. I recently replaced the cover itself. I’m the fall, I came out and heard it buzzing. I had already closed the pull, so I just flipped the breaker. This spring, I flipped the breaker on and same thing. Hums. When I try the switch in either direction, it appears to try to turn, very weakly, but stops immediately. I flipped the breaker back off.
I’m going to remove the motor housing (which is cracked as well) if I can figure it out to take a look. Any ideas welcome.
