I’m not sure what to do?? Over the Winter we ‘lost’ basically all the water from pool (honestly it most likely got sucked out by pool cover pump) so now I have a basically empty pool (about 1’ of water in it) and a cover completely sunk into pool filled with water, leaves & debris. I thought if I started to fill it the cover might raise up with the water so I can clean the debris out with a lead net, not the cover is just staying where it is as the water rises.
We had similar situation last year and all the funky water ended up in pool and by the time it filled with water it was taken over by frogs ? and it took me over a month to get rid of them. I detest frogs so I can’t have this happen again.
