- Jun 1, 2018
- 16,148
- Vinyl
- Hayward Aqua Rite (T-15)
Here’s what I mean
The check valve/flapper is inside the larger part & is fine. Its more like an air release.
Other pumps don’t seem to even have this extra piece.
I think I recall it having a ball in it. Although I never found a ball after the “incident”, could be anywhere.
It was clogged with larvae
& dirt dauber stuff - after poking with wire & spraying it out it was still quite clogged so in my wisdom I attempted to remove what looked like the hex end & expose the inside. Well, that shape was all for show & its all one molded plastic part that doesn’t come apart so of course it broke.
Now it sprays a fountain of water continuously as the pump runs
Is this a problem (aside from getting everything in the surrounding area wet)? The whole piece comes off but is not made as a replacement part you can purchase - I just called.
Can I just plug/ fill the hole? Fashion a tube to divert the water?
The wayne pump - which looks exactly like this one has this with no air release thing but is 1 1/4” on the pump side instead of 1” so not a direct replacement without some modification.
Any thoughts on solutions?
