Helping a friend put in new mesh cover for the winter. The pool and concrete are at least 15 years old, so not green concrete. Most of the existing anchors are loose or bent or both, plus the new cover has several new anchor points we need to drill.
When my pool was put in, the anchors were drilled and put in several weeks after the concrete was poured, so still green and able to tighten up around the anchors. They just drilled a tight hole, then pounded in.
The question is, what is the best way to secure new anchors in the existing holes? Any difference for newly drilled holes? I have had one anchor work loose, I used some hydraulic cement to reset it in the same hole and it seemed to work, but I have since heard/learned that hydraulic cement is actually very weak in a structural sense.
Any advice?
Any advice?
