Corrosion folks - AGP step railing
Pauls234
801
Chicago, IL
CircuPool RJ-60 Plus
Hi all,
See picture. Any thoughts on what type of paint I can use on the corroded areas? It will be submerged.
Thx
Paul
Prep work is the key here. That piece needs to be sandblasted down to bare metal and all rust removed. Then it needs to be hit with an acid metal prep. For the finish I would suggest several coats of a good automotive grade enamel.
Thanks. I don't have a sandblaster so perhaps getting new ones is most economical.... if I can find them of course.
