The electrician did not install the IC40 correctly when pool was put in. The pool installer is sending an electrician out to correct it, (as in hook the SWG to the pump relay). End of last year I had a situation where I had to turn off SWG due to high fc. In the easy touch when I set intellichlor to “ no” in the enable section, It did not turn off, it still produced chlorine...... I had to set percentage to zero for it to stop producing. Is this wired correctly? My thinking is if I set enable to “no” the SWG should be off.......? How should this be set up?
