- Aug 21, 2016
- 4
- Fiberglass
- Hayward Aqua Rite Pro (T-15)
Hello, I have an outdoor in-ground pool with auto coverstar pool cover. I'm using all hayward equipment: aqualogic goldline controller, hayward T-Cell-15 chlorinator. My current stabilizer level is between 45 and 50. Free Chlorine is at about 3 to 4 and combined chlorine about 1. Water is perfectly clear and chlorinator was cleaned about a week ago. the amps on chlorinator are at 25.64 and volts 7.24 and salt 3100ppm. the chlorinator is about 2 years old and I have recalibrated it where the display matches the diagnostic reading as advised by hayward. The chlorinator does not appear to be kicking out much chlorine even running it at 40% for 8 hours each day. I've read that the correct stabilizer level should be about 50 in the hayward chemistry guides. I'm concerned this should be higher given it is outdoors and covered most of time. Please advise on the correct level of stabilizer for my situation. Also, is the troublefreepool pool math calculator an accurate method to calculate on how much stabilizer to add? Thanks!
