Jim - This is how the relay is set up.No.. I've got some appointments this morning.. Be back later...
Jim R.
Top Left - Filter Pump - it has main power to L1 and L2. On Load 1 is VSP & Heater, On Load 2 is VSP and Heater - both are grounded
Bottom Left - Booster Pump - it has main power to L1 and L2. On Load 1 is booster pump, On Load 2 is booster pump - then grounded
Top Middle - Blower - it has main power jumper leads from Booster Pump to L1 and L2, On Load 1 is Blower. On Load 2 is Blower - then grounded
Bottom Middle - Water Feature Pump - it has main power to L1 and L2. On Load 1 is WF pump, On Load 2 is WF pump - then grounded
Top Right and Bottom Right are for Spa and Pool Light (see diagram)
Attached is my hand sketch. So I should leave the Heater on the Load Side of the top left relay?
