Converting to SWG
Does that mean you need to check chlorine levels and adjust chlorine generation daily to account for weather changes?
You've gotten good other replies, but I only change generation % 2-3 times per year. I have a before-summer and after-summer setting, then a summer setting. At all times, I'm trying to have a good buffer of FC above target so that I don't have to worry about it.
For instance, if your min is 3, and range 5-7, I will run SWCG so that I'm around 10 or so. That way it can dip a little, or go up a little, but am never near the minimum.
+1. The closer you dance with minimum the more you have to pay attention. With a healthy buffer, I can lose power for a few days at any moment and still be good. Pretty much any day i come home and the lights are still on, I don't need to think about it.
It's a weird feeling testing and not being needed for anything, and then being low key excited when it's finally time to adjust something. I mean. It's awesome. But also a weird feeling.
Reactions: Darin
