I was wrong, and called out on it. A SWCG causes some amount of pH rise, even though in theory the reactions are pH neutral. chem geek outlined some theories as to the pH rise but I didn't find anything conclusive.Good! Then I'll only have to adjust PH once during a season because that's all I have to adjust it now!
Don't bother designing it. Buy a Stenner pump or Stenner knockoff if you want to dispense liquid chlorine automatically. It's just a chemical resistant, slow feed pump. If I remember correctly, you just put it on a timer to control the output. Runs somewhere around $300-$400 for a setup. Some people here use it as an alternative to a SWCG, probably due to the cheaper upfront cost. Search on this site for more info on them.This is the part that concerns me. This is the time I most want/need a system that feeds or generates automatically. The rest of the summer when my wife or I are around, it's a matter of walking out and adding about 1/2 gallon every night. This is why I'm debating SWG vs designing a system to automatically dispense chlorine throughout the day. I could program a pump to dispense a measured amount two or three times throughout the day and keep my chlorine levels at a pretty steady level but that requires me buying and storing chlorine which I'd like to get away from.
Personally, I'll be doing a SWCG on both our future spa and pool, since while a pump gives you the constant chlorine additions like a SWCG, you still have to buy/lug tons of chlorine bottles around, and remember to check and refill the pump reservoir. Plus there's just too many members here saying they would never put in a pool in the future without a SWCG. I can't ever remember seeing someone say they put in a SWCG and hated it. A couple of people mentioned rust after SWCG, but they either had cheap pools and rust was reported on similar brand non-SWCG pools in similar time frames, or they had had the pool for several years already and the rust appeared after a season of SWCG. Chances are good they would have gotten rust without the SWCG had they waited another season. In other words, "correlation does not imply causation."
