I already have an intelliflo pump and have been kicking around going saltwater. i see they have the easy touch4 and 8 that you can buy as a package with the salt cell. I have a pretty basic setup. 18000 gal pool and fountain feature that has its own pump. I plan on re doing the plumbing and going down to 1 pump so i will need 1 actuator I think. a couple questions. I run my pump on a higher speed for 2.5 hrs then kick it down to very low. will the salt cell shut itself off when i go low enough rpm? if not can i make it shut off. so all i need the controller for is to run the pump, salt cell, pool lights, and have the ability to turn the fountain on and off.i also may tie in outdoor lighting in the future. what would you guys suggest?
