The salt generator has a flow switch so even if it's not on a timer, it will shut itself off when the flowswitch shows the pump is off. So do i really need to have the salt cell on a timer?I converted my single speed whisperflo to Variable speed and love how quiet the new pump is. The pump now controls the timing of operation so I set Intermatic time to operate 24/7. This inadvertently left the salt cell (aqua rite) controller on 24/7. Researched here how to add a relay to measure pump voltage and got lost. I decided my easiest route is to keep the aqua rite on the intermatic timer and move the power for the pump inside the timer to the main. Now I coordinate the intermatic timer with the pump timer but once set will only require coordination after power outages. Hoping this helps some other DIY find an easy solution to pump upgrades and old fashioned controls.
MOD NOTE-moved from here: Converting pump to variable speed with Intermatic timer and salt cell
