Flying Tivo
- Jan 24, 2017
- 2,954
- Plaster
- Pentair Intellichlor IC-40
The tarp method will not work for a baquacil conversion. Homeplace did not drain the pool to reduce CYA but to reduce the amount of a baqucil product, CDX, that prolongs the conversion process. Even with a drain and refill you must go through the conversion process to eliminate any remaining baquacil in the plumbing and filter.
I assumed so, but the conversion with 90% of baquacil gone, should take a lot less time than the full load and keep the liner from shifting. Don't you think?
