I've been testing my pool water for months and have maintained what I consider a nearly "perfect" chemical balance. I was keeping my FC at 5 to 6, which is well above the level called for in the Pool Calculator, yet I continued to get a dusting of algae in my pool. After hearing from a fellow Floridian with a similar issue, I raised my FC to between 8 and 10. To my surprise, I continue to get a dusting of algae every 3 to 4 days, in the form of light spots on the walls and floor of the pool at random locations. The water is crystal clear, and I don't believe it should be necessary to brush the pool every day to keep algae at bay.
I can physically feel the circulation of the pool water, so I don't have a "dead spot" issue or lack of circulation, which was my last option to consider as to why I keep getting algae. I've increased pump run times and speeds, increased the output and run time of my salt system, etc., to no avail. I won't get into the gory details, but trust me, I'm running everything much longer than should be required, and keeping FC higher than should be needed to boot. Then I thought, is there a chlorine resistant algae I'm dealing with? I slammed the pool twice, both times passing the OCLT test with flying colors. The second time, I passed the OCLT test twice, yet the algae returns. I can still pass an OCLT test, and typically have a CC of 0.
Intrigued? I am, and no, I'm not going to post my test results, because I don't want to go down the path of discussing chemical balance. I've got that covered in spades!
I know the topic of phosphates seems taboo here on TFP, but I'm beginning to think there may be some merit to opening a discussion about this, as I've exhausted every other avenue. Algae should not present with a maintenance level FC of 8, so something is going on in my pool, and perhaps hundreds of other pools. Has anyone noticed a dramatic increase in "can't get algae out of my pool" posts?
Something beyond the basics is happening, at least in my case, and I'd really like to explore a remedy.
Thoughts?
Thoughts?
