I'm at my wits end with this algae problem. I'm just opening the 16x32x52 pool for the season and due to unforeseen circumstances, I didn't get to shock or add chlorine after I pulled the cover off. Fast forward 2 weeks and it is dark green. My daughter thinks alligators live in it. I vacuumed the best I could due to not being able to see 6" into the water, backwashing every 10 minutes due to pressure loss. Then I adjusted the PH as it was off the charts. Got it to around 7.3 and adjusted the TA as it was bottomed out. TA is now around 100, PH is 7.5 or so, Calcium is really high, and CYA is 66. I dumped 3 bags of "concentrated shock" and it turned it bright anti-freeze green. Vacuumed and scrubbed. Then using the calculator, I dumped 4 gallons of LC 7.5% into it. No change and almost empty on FC yesterday morning. So last night I dumped 5 gallons of Clorox bleach into it. This morning no color change and FC is around 4. So then I dumped another 5 gallons of Clorox in it. Wife says the water still looks the same. I won't be able to add more or check FC until tonight. When I backwash now, water coming out looks clear. I assume it has to be an algae issue as I am losing FC like nobodies business.
At what point am I better off to just empty it and refill? I've spent about $150 on it so far and not getting anywhere. Water is cheap in my area and I can drain/refill for about $100. Plus the kids could swim by the weekend.
