- Mar 25, 2019
- 554
- Plaster
- CircuPool RJ-30 Plus
This isn’t the first or second time I’ve cut this area.. once for a leak and once to replace the rainbow diverter tee so I have too many couplers already to even fit the vertical setup. I am just going to have to redo that run of pipe. I’m pretty comfortable fabricating it all up. The guy at DSP admitted his kit is nothing special, just fitting and pipe trimmed to the right length. For 30 bucks I didn’t think it was too overpriced.
Also I’ve never had luck dry fitting PVC pipe as the fit is too tight. I just add the connection length to my measurement (.75 to 1.5 depending on the fitting or valve) and hold the joint together for about 30 seconds as it will back itself out while everything is still mushy.
