The title about sums it up. I have the opposite problem of so many.. I can't keep CYA consistently high enough. I first started noticing it last year. It became more pronounced at the beginning of this year. Pool has been open about 10 days.. tested CYA right around 30 on opening(Taylor R-0013 test). Today was surprised to find chlorine at zero and I tested the CYA and it was essentially at zero.
I do struggle with big water loss. I lose between 100-200 gallons a day out of a 20,000 foot pool. Live in the Midwest.. pool is 16x36.. so big surface area, lots of sun, very breezy, no cover(this one will be remedied soon).
In the past 10 days since opening we have also done a serious vacuum to waste, added water to fill on opening and have had three torrential rainstorms. But still seems odd to find CYA at zero.
Any thoughts or ideas on what is causing this? I didn't think anything could really cause CYA to dissapear.. and even figuring maybe I've added 5000 gallons of fresh water in 10 days it shouldn't have gone down this much. Or is the problem simply I'm testing wrong? I suppose that is possible.. but my struggle to maintain chlorine indicates a lack of CYA.
Ultimately I'm guessing I might have to develop a hybrid routine of using both liquid chlorine supplemented with dichlor and trichlor. Or maybe a solar cover will make more difference than I think. But is there anything I'm missing here?
Chris
Chris
