Considering SWG
Fugacity
6
St. Louis, MO
Fiberglass
After (over) thinking a diy automated liquid chlorine injection system, I've come to the conclusion that switching to SWG is pretty clearly a better idea.
I'm looking at circupool RJ45 for my ~20k gal pool (details in signature).
Is the 45 a good choice? Is going bigger better? Other options, hints on installation etc would be helpful. I'm an engineer, and competent in diy plumbing, electrical/automation etc.
Thanks in advance
F,
The 45 will work, but bigger is always better when talking a SWCG.. The bigger it is, the longer it should last, at least in theory..
I am not all the familiar with CircuPool SWCGS, but you need to make sure you can adjust your output by 1 or 5% increments.. I think some of their cells can only be adjust by 20% increments, which is not ideal, in my mind.. Double check the adjustments before you buy any cell.
