Jen318
Good to know. I’ve noticed the limestone builders block everyone uses on their houses flakes off during freezes so yes could just be the stone they use around here.
I do have a water sheer and if I remember right, we bumped it up a bit because that looks really sad when it's not at least at 2200. Although with the ScreenLogic, I would be able to trigger that combo of if the waterfall is running, go up to 2200, right?Frog,
If you don't have a spa or heater that is way too fast to be running your pump from and electrical point of view.
I run my IntelliFlo 24/7 at about 1200 RPM for less than $20 bucks a month. I do this because I like to make a little chlorine all the time and I like to skim all the time. At that speed my filter pressure is about 1 lb.
Now that I think about it, I am not sure how fast you need to run your pump to dissolve those chlorine tablets that I suspect you are using..
Since you have a good test kit, you can reduce your speeds, and monitor your FC, and see what works best for you.
Do you have a controller, or are you just setting the speeds on the pump itself?I do have a water sheer and if I remember right, we bumped it up a bit because that looks really sad when it's not at least at 2200. Although with the ScreenLogic, I would be able to trigger that combo of if the waterfall is running, go up to 2200, right?
Honestly, the speeds are just what the installers told me to set and I never questioned it. How would I go about figuring out a better speed for my pump? How would I know if I'm too high or too low so that I can dial in to the right speed for my pool?
I do. I use the ScreenLogic app and the waterfall is only on when people are swimming. I guess I'm just not sure what I bump it down to. How do I figure out the right speed for just general filtering?Do you have a controller, or are you just setting the speeds on the pump itself?
I would consider scheduling the time I want the waterfall effects and slow it down when nobody's going to be watching it.
One said no problem at all to install, the other said they'd have to completely drain the pool to do it because otherwise the existing water in the pool can damage the new system. Um. What?
Probably not. Can you post some test results? Sulfates from the use of dry acid, high CYA, and high CH can create problems for SWGs.Anyone know whether I'll have to drain the pool?
We don't test for sulfates. It's moot issue anyways.I honestly never asked if he was using dry acid or muriatic because I just assumed everyone used muriatic. I don't know how to test for sulfates. I have a TF-100.
This is not a moot issue. I have to say it though...you'll need to exchange about 50-60% of the pool volume to get CYA into range. Tablets (trichlor) are bad news.I am terrified to do a partial drain, which I suspect is what I'm going to be recommended. I've read about it here, but I still can't quite picture it and I'm convinced I'm going to do damage.
I found this and it was neat with regular updates. Of course it's not exact and 1/2 mile from the nearest well could have different results, but if the whole area around you is 200 ft deep, (or 600 ft in Katy, fun fact of the day) you can worry less.I'm convinced I'm going to do damage.
Thank you!I found this and it was neat with regular updates. Of course it's not exact and 1/2 mile from the nearest well could have different results, but if the whole area around you is 200 ft deep, (or 600 ft in Katy, fun fact of the day) you can worry less.
Can you confirm you used a 10 mL sample, not a 25 mL?I wonder if I’m doing the test wrong then. It’s supposed to turn blue, but mine goes from red to clear. User error?
Just redid the test and yes, all of that is correct. It was my math that was off. It turned pale blue at 20 drops this time, which is 500. Thoughts on that calcium level?Can you confirm you used a 10 mL sample, not a 25 mL?
Each drop counts at 25 ppm?
So, no softener, correct?
The blue is somewhat faint, but it is blue.
It's ok for now, but when you drain for CYA, you CH will be in a better spot. Optimally, you want to get your CH as low as possible since it will continue to rise with evaporative top offs. Any chance your home has a water softener you can tap into? If so, you may never need to drain again.Just redid the test and yes, all of that is correct. It was my math that was off. It turned pale blue at 20 drops this time, which is 500. Thoughts on that calcium level?
