Our pool has main drains. For the first several years, my cleaning process was to brush the pool, moving all the dust-like debris towards the main drains. Then I'd put in the pressure side vacuum. Even after vacuuming, I'd still have that dust-like debris on the bottom no matter what.
Now I have a robot and rarely brush. But also have almost no dust-like debris.
A few observations. My filter cartridges the first few years with brushing and a pressure side cleaner were quite dirty. Pressure indicated I definitely could not go all season with less than a 25% rise in pressure. Now using a robot and not brushing, but having a dust free bottom, pressure rise indicates I could pretty much go a whole season in MD without cleaning the filter. And when I did opt to clean them last weekend, they were noticeable cleaner than before.
So although you will get a bit more circulation with a main drain, my experience is that with a low efficiency (bad cleaning) vacuum (pressure side cleaner), there was more benefit to having a main drain (sucked the dust out that I stirred up). But with a robot to suck out all of the dust, I no longer have the need to have a main drain to push that type of debris towards. That said, I still appreciate having the main drain for circulation, though my pool is 8 1/2' deep. Though I have no real feel for how much difference it makes. But the drain sucks in as much water as a skimmer, because it has the same size pipe and suction pressure would be the same.
Not maybe what you were asking for, but some details on my system and thoughts.
After seeing this post (and many others) I'm set on getting rid of my suction pool cleaner. I feel like there is always something to replace/fix on it and it doesn't clean as well as I'd like it to. Spend way too much time brushing, replacing bag, etc and removes the joy of owning a pool. REALLY wish I didn't already replace practically every part on it including all hoses, fittings, AND the booster pump.
I'm going to continue doing my research on the best one to buy but in the meantime any ideas on what I can do with my old components when I get one?
Unsure when the best time to grab one is and probably should have decided to do this at the beginning of the pool season LOL
