Greetings All,
I was thinking of doing a DIY sprinkler or maybe "rain fall"/shower thing (the kids really enjoyed at the kiddie pool while on a cruise) - I was thinking the easiest way would be just to drill some holes into a pvc pipe with the elbows and caps and connect it (not permanently) to the return.
What would be the name of that fitting that can go into the return outlets (2x 1" outlets) and connect to pvc pipes? - I recall seeing something that looked like it had a rubber seal that you could compress to be pretty tight to the inside of a pipe once - would this be the right thing to use? If so, what is it called?
Thanks!,
Bob
Thanks!,
Bob
