I purchased the Taylor K2006C kit and went to use it today but it appears as if I might be missing some chemicals. In the instructions for testing free chlorine it talks about drops of R0001 & R0002 but I do not have any bottles with those numbers on them. Am I missing something or did I purchase the incorrect kit?
My initial test with this kit has these results
CYA probably around 175 or so, it only took about a 1/2" of water in the tube for the black dot to disappear. I will need to dilute my water sample down and retest then do some math to determine what my CYA really is, I already drained about 10,000 gallons out of the pool and replaced with fresh water. At least according to my water bill!
TA 80
PH 7.2
FC 10
CC 2.5
Like I said, this is my first time using this kit so it is possible that I did a test or two incorrectly but I do not believe I did.
I manually brushed (with the new whale tale and WOW!) and manually vac'd (Nautilius CC Plus Died) into my new cartridge filter system. The water sparkles and has no smell and I swam today and it feels good too. I know the CYA is too high and I know I use tablets but I am not here fulltime to add Liquid every day so I must for now, fight the CYA problem
Thanks for any input!
TA 80
PH 7.2
FC 10
CC 2.5
