Hello.
I want to change my pump (0.75 single speed hp, 2'' pipes) to a VSP, because I'm gonna add a SWG, but also because I'm so very done with how noisy my current pump is.
So I've seen most people around here recommending a 3hp VSP pump. The thing is my pool is both simpler (one skimmer, one vacuum plug, three returns, no features) and much smaller (around 7500 gallons) than what is usually seen in this forum.
I know you can just run the pump slower, so I'm worried I would be overspending by buying a much more expensive pump than makes sense for my pool, and that I would have to run it at so low RPM that the SWG wouldn't run.
On the other hand I'm also worried that if I go with let's say a 1.5hp VSP the noise difference with my current pump won't be much.
And there's something that makes me very confused. I have seen in local stores three VSP models that offer both a 1.5hp and a 2hp version, and in all three cases the 1.5hp was rated for 2'' pipes while the 2hp was rated for 1.5'' pipes. How is this possible? I know smaller pipes have more friction, but how can that offset the fact that you have to move much more water (and so I assume more hp or more RPM) through the bigger pipes to achieve the same flow rate?
