C CGA New member Dec 24, 2023 1 Tyler Texas Dec 24, 2023 Add bookmark #1 i have an in ground pool-spa with a Compool Cp 3000 pool spa control system. The jets/air is coming on going off randomly
ajw22 TFP Expert Gold Supporter Silver Supporter Bronze Supporter TFP Guide Jul 21, 2013 65,118 Northern NJ Pool Size 35000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-60 Dec 24, 2023 Add bookmark #2 Welcome to TFP. Do you have an IS-4 spa control panel? If you do then disconnect it at the Compool panel. You are probably getting spurious key presses on one of your control panels.
