Hello I need help with my automation . I have a compool to easy touch conversion . The spa actuator valve on the pump side goes back to spa mode in the AM start up.
It is then only returning water from the spa back to the filter. The top button on my indoor controller is for spa mode and is on and led lit . When I press the button it returns to normal pool mode.
Can someone help figure out how to fix this . I think it's a programing issue. Ive been through the menu several times and read the PDF file .
Should I erase the eprom and reset the system . I don't really want to go that route.
Thank You
Bob C
Thank You
Bob C
