Just a little background, I had a 360 for over 20 years. This pool is setup with a center outlet for it which helps
It stayed in the pool 24/7/365 unless I am worried about it freezing,
Early 2020 it needed rebuilding and at the time I thought the parts were expensive so bought a Pentair SE for $699 and got a $50 rebate so was happy..
In early 2023 my robot quit and although it needs a impellor motor that should cost $50 Maytronics makes you buy the whole assembly for $450
Should note my motor had water in it so a seal leaked.
So i decided to go back to another 360 and found a used one for $210, had to spend another $45 on a piece of hose and a float but it look's brand new
Should also note I have a lot of hardwood tree's around me so I get tree junk..People in the south will understand
Roboot Advantages over Polaris
It does clean better, mainly with the small grit on the bottom
It was less of a hassle, cord sometimes got tangled but nothing major
360 Advantages Over roboot
It does a better job keeping the pool clean over all. It will run 24/7 as long as my pump is on.
It does a better job with bigger leaf's
PARTS! I used to complain that $125 rebuild kit was a scam but compared to a $450 motor its cheap
Plus you can buy every part separate, most of the ones I replace are $20
A lot of folks on here have Robots and never have issues. But once I started looking around a lot of us have.
Not sure why unless it has to do with water temp and taking it in and out. As mentioned mine stays in especially from early spring until summer.
If they designed it to last more then 3 years I would have bought another one.
