Comparator Light
mkflyfish
23
Overland Park, KS
Pentair Intellichlor IC-40
I usually run tests indoors and like many of you, I'm the worst at reading pH. I'll see 7.7 through 8.0 as the same. Occasionally, I'll use my K-1001 test kit for pH as the comparator range is 7.5, 7.8, 8.2 and I can more easily tell if the pH is above or below 7.8
Is there a light that is recommended for comparator, other than Taylor Comparator Light ? Would a 5000k LED be similar ? A specific solid color on monitor ?
Any other suggestions ?
thanks,
Michael
