That is what appeared on the display of my one-year-old Pentair Ultratemp heat pump. 3 days ago I looked at the pump's control panel and it was not backlit. I went to the breaker box and there was a tripped breaker. I reset the breaker and returned to the pump. There was power to the unit and everything seemed fine. I turned it on . . . everything seemed fine . . . the fan was working. I noted that the water temperature was 84 degrees and the thermostat was set ay 87 degrees. I came back a couple of hours later and everything still seemed just fine but when I looked at the water temperature it was still at 84 degrees. I stuck my hand into the pool in front of the return and the water coming into the pool was the same temperature as the water already in the pool. I turned the heat pump off and left it off until the next day. When I returned I was not able to get the pump to start and the words "Comm Port Lost" appeared on the control panel display. Ideas?
