Howdy all. I am using an Australian liquid test from Clear Choice Labs. Very good product although pH can be tricky to read with the colours. The FC and CC is measured in 0.5ppm increments. I find I always have 0.5ppm CC. Is this acceptable?
Yes it is.I find I always have 0.5ppm CC. Is this acceptable?
Its a spa and that’s not uncommon in a spa that may have had fc dip below min.Why would that be in your pool to begin with?
Are you having issues with that? Aka hot tub rash?Excellent. Could pseudomonas aeruginosa still be present if that’s the case?
I might be. I really don’t know. Doctor thinks it is.Are you having issues with that? Aka hot tub rash?
If so its time to purge, drain, & refill even if cc’s aren’t elevated.
Try cleaning your test cylinder with alcohol and see if you’re still showing persistent cc’s to rule out interference.
While cc’s of 0.5 or less are acceptable & to be somewhat expected in a spa (especially if you test right after use) if they become elevated above that & a couple of slam fc level rounds don’t lower cc’s back to acceptable ranges its time to start over.
Cc’s are simply 1 indicator of the health of the water.
