I'm a new hot tub owner, and I've been reading the sticky threads and trying to follow all the instructions, but I'm still uncertain on a few points.
Here's my situation:
I have a Caldera Salina with the Watkins Saltwater system (420 gallons).
I've been using it for less than three weeks.
My chlorine source is the SWG, but I supplement with dichlor as needed and then switch to bleach after I've added ~30PPM CYA via the dichlor.
I use test strips for quick checks (e.g., to verify that some free chlorine is present), but use a Taylor FAS-DPD test kit to double-check it and get more precise readings.
After my first fill, we used the hot tub a lot and the combined chlorine level reached ~2.0PPM in less than two weeks. I tried super-chlorinating, but it didn't seem to help, so I used Ahh-some, emptied, and refilled.
For my second fill, I balanced to ~70TA and added 40PPM borates for Ph stability. In less than a week of use, combined chlorine was back up at 0.5-1.0 (as measured using the Taylor kit). I understand that the solution to combined chlorines is to superchlorinate at 10PPM or greater, so I added 2 tablespoons of dichlor (raising FC to roughly 12PPM) and turned the SWG off temporarily. 18 hours later, FC is 6PPM and I'm still measuring 0.5-1.0 combined chlorine. Ph is 7.5.
What should I do now? Is there any way to get rid of combined chlorines without making the hot tub totally unusable for 1+ day per week or spending a fortune on MPS?
