How do we use these hoses to hook pool back up? My husband is ready to trash this pool as the hoses Dry rotted and we can’t find any that work properly? I ordered these in pic.
If there is normal PVC fittings like second pic you can hard pipe or flex pipe scedule40 PVC like found in homedepot. For the flex you have that is like 1 grade higher than sump pump discharge hose. That attaches with barbed fitting found in sump pump section. They have threads on back so you use hose clamps and thread into female PVC adapter. IF the filter and pump have threaded connections and the barbed is threaded in you can unscrew and get Male PVC connectors and just hard pipe and glue it all. Somebody with basic pipe knowledge could knock this out in half an hour with the right fittings
