Hello everyone I’m new to the group! I’ve recently put up a Coleman above ground pool and today I went to turn my filter on and the test button seems to be stuck. Has anyone had any issues like this before.
This may sound simple but- Have u tried plugging it in & pressing the reset button?
If that doesn’t work & u are sure things didn’t get wet or create a ground fault condition that needs to be remedied you will need to replace it. If the pool is new it should be under warranty & they may send u one.
In the meantime You can get one at the hardware store like this
The Portable GFCI units (Ground Fault Circuit Interrupters) offer protection for 2 wire or 3 wire appliances and tools to avoid electric shock for people in all work environments. They are perfect for
www.homedepot.com
Or
if you already are plugging it into a gfci, you can use a regular weatherproof cord cap.
