So, I want to close my own pool this year. I have read the thread on closing and I believe I have a good grasp on things. I do have a couple of points I need clarified because if this goes bad my wife will say "I told you to just have it done!"
Here is some background. This is the first year I have moved away from the pool company for water clarity. I have the TF-100 and love it. My water has never looked better. I have spent a fraction of what I have spent in past years!!! So, THANK YOU TFP!!!!!
The pool company closing has been a "piece of mind" thing for the last three years. In my head, if they close it they own any damage that occurs during the winter. In the end, I'm not sure if this is totally true. They charge $350 and are in and out in 45 minutes and I don't haver to do a thing. They don't drain the pool which I am a fan of. I don't know why honestly maybe its chemicals going down the drain or filling with water in the spring.
This year I am going to purchase a cyclone so the closing cost will be a wash this year. I have some questions as to how to proceed with my pluming setup. I have a sand filter. A heat pump and a hayward super pump. I have two valves in my setup. One of the valves splits the skimmer and main drains and the other splits the returns and four deck jets. I have attached some picks of my setup.
I am not sure where to place the cyclone hose to blow out the lines and clear the heater. That is my first question. Once I get a handle on this here is how I think this should go from all I have read.
1- Start with the returns. Plug the closest one to the filter first and then the furthest. Turn the valve to open the deck jets. Once they are cleared pour some anti freeze down the furthest deck jet. Turn the valve back to close the deck jet line, leaving the returns open but plugged.
2- Open the skimmer line and blow out the skimmer line with the gizmo in place with an open blow hole. Once cleared turn off cyclone, pour anti freeze down blow hole and put plug in gizmo. Turn the valve to open the mains and blow them out until they are clear. Turn of blower and quickly close off main drains by turning the valve to open the already cleared skimmer.
Obviously I will pull all the plugs off the filter and skimmer basket. I will disconnect the union at the heater to drain it???
Please let me know if this sounds correct and where the cyclone hose is best placed to do this.
I want to drink coffee this winter!!!!!!!! I just need to be certain as to what I'm doing or my coffee will become alcohol when my wife says....."I told you to just have it done!!!!"
