But....It has been working perfectly fine for 16 years.That will not work.
The service heater light coming on is due to the fact that I'm turning on the Jet Pump and by doing so I'm "introducing" the problem.
Is the heater the original heater?But....It has been working perfectly fine for 16 years.
No, nameplate shows it is from 2013 so I'm guessing it was replaced 8 years ago. I purchased the home almost 3.5 years ago.Is the heater the original heater?
Here you go. I included a video of what happens when the Jet Pump turns on. All jets have increased flow when the Jet Pump is running.Can you show pictures of the spa?
You don't know that "It has been working perfectly fine for 16 years".I purchased the home almost 3.5 years ago.
There's 10 and yes, water comes out every single one of them.It looks like 11 returns.
Are you sure that water comes out of all 11 for each pump?
You are 100% correct. I made an assumption it worked fine for the past 16 years. You are also correct in that I have had issues and I had completely forgotten about the 2nd one you linked to. That was resolved by setting the filter pump speed to 3450 rpm for "Spa Heat" so maybe that's worth a shot again.You don't know that "It has been working perfectly fine for 16 years".
All you know is the 3.5 years that you have been there and your previous posts indicate issues with the heater.
Not sure about this. Will try and check next time.You have 4 suction inlets.
Are you sure that both pumps pull from all 4?
