sande005
- Aug 19, 2018
- 1,037
- Vinyl
- CircuPool RJ-45
Depending on the situation, the pool pump can put out a surprising amount when going to waste. It's how I lower my pool below the jets each fall. Using that, combined with the rental, likely will give you more capacity out than the truck uses to pump water in. A conversation with the hauling company should give you an idea of how fast theirs goes in, so you can roughly match what is going out. Then it is just a matter of turning pumps on/off as needed when the new water is being added....
