FiguringItOut
1
Maryland
I purchased a home and it came with an above ground pool. During the home closing process, the pool owners moved out and left the pool without maintenance. There was a significant algae problem. We believe we have resolved the algae issue and have balanced the pool for the most part. Now we are left with cloudy water, mostly a white color, that will not go away with constant filter usage or with clarifier. Not sure what else to try.
pH has been the only issue as we are struggling to get it past 7.2, it is usually hovering in the 6.8 range regardless of what we do. We are looking into aeration devices to assist.
Current readings:
Free Chlorine 3
Total Chlorine 3
pH 6.8
Alkalinity 120
CYA 50
Hardness 250
The Chlorine levels have not dropped and stayed steady for a week now. We have vacuumed the pool, put in brand new cartridges in the filter, clarified twice about 3-4 days apart, and run the pump and filter nonstop for about 3 days (we had to fix a leak and paused it for a day or so to resolve that).
Welcome to TFP!!!
How are you testing your water?
If you don't have one of the kits we recommend, get one. Link-->Test Kits Compared
Why? You need one to SLAM. Test strips and pool store test is usually wrong, and if we give advice on wrong testing, we can do harm.
To clear your pool, follow the SLAM process here...Link-->SLAM Process
Proof? Link-->>How Clear is TFP Clear?
Reactions: HermanTX
