You guys! I came home and my pool water was clear! I don’t think I have ever been so exited to see a clear pool! Now. There were clumps if brown sand stuff on the bottom. I assume this was from backwashing into my pool for the last month. I got in and vacuumed and washed the walls and skimmed it. This made it a little cloudy again-which I figured it would. I then backwashed (the water coming out was disgusting) and rinsed. I tested my FC and it was only at a 18 so I added the recommended chlorine. My next questions are:Yes, keep the SLAM process going, you may not have been filtering anything. And the backwash may not have actually been a backwash. Who knows what route the water was taking with the valve all messed up.
You really need to get a gauge so we can see if the filter is capturing anything and to know when the pressure rise 20-25% above the clean pressure.
I might suggest you backwash some now and see what the water coming out looks like.
*If my water is clear again tomorrow how long do I keep doing the SLAM process?
*What are my next processes after SLAM?
*While I maintain the pool do I just keep using liquid bleach? I have read a lot of forums on here and most people say just to use that and don’t bother with the tablets. I have no preference either way
*How often should I use my test kit? What they card says?
