Hi there.
I got cloudy water today and wonder why.
FC 3
CC 0
CYA 40 or 60
PH 7.6/7.7
CH 250
TA was around 110 when I opened. PH has been steady at current reading, while it was always climbing up prior years.
water temp 82 (was over 90 yesterday or day before). lots of rain yesterday, but last night water was clear. Filter cartridges are old, but were rinsed 6 days ago.
I have two CYA R0013 agents - one from Leslie's and one from TF100. Both from last year.
I used Leslie's one to get my CYA to 30, but during sunny days FC was going down from 6 to 1/0.5 (1 gal of 12.5% added at night, tested 24hr later), on cloudy days it'd go down to 2-3. I never used more than 2/3 of the same 12.5% gal prior years, but that was with CYA around 35-40. My liquid chlorine seems fine, even-though it's a few months old.. after adding a gallon in the evening I have 6ppm in the morning, very little chlorine loss if any
Then I decided to test water using TF100 (R0013). This test result was 20ppm, so I figured Leslie's stuff must be bad (which would explain why I was losing more chlorine than ever before (Leslie's R0013 showed ~35)) and I added more CYA to bring it up to 40. Today, 4 days after adding CYA - cloudy water.
https://photos.app.goo.gl/5GrMeAjgvz9yC2MP9
Today's CYA test results
Leslie's - 60
TF100 - 40
TF100 was purchased last year from ebay seller "pool supply world". I asked seller to reply on this forum to confirm they are authorized re-seller and I'm pretty sure they did and they said their stuff is fresh (I can check prior posts to confirm)
Given the difference in CYA reading, which R0013 would seem to be more accurate? Would older R0013 have lower or higher CYA reading?
Is it safe to swim in cloudy water?
Could old cartridges have anything to do with water getting cloudy\haze overnight? Cartridges were cleaned a couple days before adding cya.
The only chemicals I've been for the last few years are 12.5% chlorine, muriatic acid, clorox stabilizer. This year I switched to hth acid and hth stabilizer (because of the price, although dosages are slightly different - 1lb would raise cya by 10ppm in 12k gallons(clorox), 10k gallons(hth). I don't know if it means different strength of the products. hth is what I used to raise CYA from 20 to 40 (or 40 to 60, using leslie's R0013 )
Thanks
FC 3
CC 0
CYA 40 or 60
PH 7.6/7.7
CH 250
Leslie's - 60
TF100 - 40
Thanks
