Hello. I had some metal staining and treated my 10K gal plaster pool with 1lb of Ascorbic acid. The stains were lifted and after 24 hrs I added "Metal Gone" At this point the water was still pretty clear. Then I added 10ozs of "Sea Klear" (per instructions from the pool store.). The water immediately started to get very cloudy (like couldn't see the first (top) step cloudy.) After looking on this site I found that "...Clarifiers should NEVER be used ... where Metal Sequestrant is being used" Unfortunately I didn't see before adding it.
I've been running the cartridge style filter / pump nonstop for 7 days now and have cleaned the filter every day (quite a bit of fine white dust (same as in the pool) has been coming out each time its cleaned, and the water is a little clearer, but not very much. At this rate I think to will be months of 24/7 running before its clear agin. The pool water is pretty close to where it needs to be chemical wise: Chlorine 2.0, PH 7.6, Total Alkalinity 90, stabilizer 50, Calc 310. Any suggestions on what I can do to speed things up a little?
Attached is pictures of the Metal Gone and the dreaded Sea Klear bottles.
Thanks.
Thanks.
